LMS releases LMS Test.Lab Rev 10 with increase
作者:Simwe 来源: 发布时间:2011-06-28 【收藏】 【打印】 复制连接 【大 中 小】 我来说两句:(0) 逛逛论坛
LMS International has released the latest version of LMS Test.Lab, its integrated solution for noise and vibration testing and engineering. LMS Test.Lab Rev 10A not only offers significant improvements in productivity, efficiency and user-friendliness, it also introduces new applications, such as Time Domain Transfer Path Analysis (TPA) and MIMO FRF testing. Rev 10A integrates innovative solutions for acoustic testing – making LMS Test.Lab Rev 10A the most complete acoustic package on the market.
Bruno Massa, Vice-President Test Division at LMS International, “LMS Test.Lab is the solution that testing departments count on to increase test productivity while maintaining the utmost product quality. With Rev 10 of LMS Test.Lab, we continued to improve on efficiency and ease-of-use. With the integration of new acoustic testing capabilities and transfer path analysis techniques, test engineers can more efficiently trace where a sound is coming from and what the root cause is of particular noise and vibration issues. This significantly increases test productivity and delivers more reliable results.”
LMS Test.Lab Rev 10A delivers a new extension to the renowned LMS Test.Lab Transfer Path Analysis capabilities: LMS Test.Lab Time Domain TPA. This new application complements frequency domain TPA and is the perfect solution for the analysis of transient phenomena. With this extension, LMS now offers a complete portfolio of TPA solutions for a broad spectrum of applications. The new LMS Test.Lab MIMO FRF Testing extends the modal testing techniques in LMS Test.Lab. With this new solution, users can specify their specific excitation signals, define a shaped amplitude spectrum and extend the application to multi-sine excitation.
LMS Test.Lab Rev 10A integrates new acoustic testing capabilities and scalable solutions for spot-on sound testing and analysis. The LMS Test.Lab Rev 10A Sound Quality solution has been extended with new psycho-acoustic metrics used in the automotive, aerospace, and white goods sectors. The LMS Test.Lab Sound Intensity’s geometry module has been extended with a 3D acoustic mesh generator. The new intensity data sheet presents a clear overview of all measured and processed data, quality indicators and related components. User can easily analyze, browse and interpret data for sound power, source ranking and sound source localization.
The LMS Test.Lab Rev 10A High Definition Acoustic Camera supports both real-time far field and real-time near field sound source localization. The camera’s array with wide angle lens provides sharp pictures even when taken close to the structure. For interior sound source localization with maximum accuracy, the new LMS Test. Lab 3D Acoustic Camera has a laser that automatically scans the geometry without operator intervention. During the scanning, pictures are taken to obtain a full 3D photorealistic image of the vehicle. With this solution, users can spot sources of interior noise problems with high precision and in record time.
Finally, LMS test.Lab Rev 10 takes optimal advantage of the new E-series signal conditioning input modules of the LMS SCADAS, which offer enhanced usability and increased efficiency. The E-modules provide a hardware-based solution to ensure faster test set-up and accurate measurements without data loss, even for demanding applications with high-channel count.
