In addition to generating a mesh TrueGrid® can generate most of the non-geometric components of the model needed for pre-processing.
Loads and Conditions
Loads and conditions can be assigned to various parts of the model.
This includes:
There are two ways to assign these loads and conditions to portions of the mesh:
- Make assignments to selected regions of the mesh in the part
Make assignments to nodal or face sets in the merge phase
NOTE: there are numerous ways to create sets for this purpose.
Constraints and Boundary Conditions
With structures, a node can have a reduced set of degrees of freedom. Such reductions can be applied in the global coordinate system or an arbitrary local coordinate system. A special case is nodes placed on a symmetry plane. It is also possible to constrain a set of nodes so that they are forced to move together. Joints have properties where the movements of the nodes of a joint are coupled. Nodes along a stone wall or a symmetry plane with failure also have restrictions on the movement of some nodes.
With fluids, there are various boundary conditions such as an inlet, an outlet, or a wall, just to name a few. The list of possible boundary types is different for each fluids code. |
All of the these constraints and boundary conditions can be applied by selecting a region in the part phase. In many cases, they can also be applied to a node or face set
Contacts and Interfaces
Some structural codes have a contact surface feature. In many cases, two opposing regions of the mesh must be identified. Also, these contact surfaces have characteristics that must be identified. In LSDYNA, one can couple shells and bricks by forming a set of fibers along the face of the brick elements
The faces that form the contact surfaces can be identified in the part phase by selecting a region of the mesh. Alternatively, a face set can be selected for a contact surface
Properties and Element Types
Most simulation codes have a set of properties associated with each material model. These material model properties and the associated element types can be selected. Then elements are assigned a material model. This can be done by either selecting a region in the part phase or by assigning the material model to an element set.
Analysis Options
In order to run a simulation using a model from TrueGrid®, one must first identify the analysis options and other global properties of the model. Many of these options can be selected within TrueGrid so that the final output file from TrueGrid® can be imported to the simulation code, without modification to this file, and run.
